gnanicys
Python debug or running script does not produce any results.
Discussion created by gnanicys on May 6, 2014
Latest reply on May 8, 2014 by gnanicys
I'm using the very last code titled "start simple" found at the site here http://blogs.esri.com/esri/arcgis/2013/07/30/scheduling-a-scrip/
When I debug it in python 2.7.3 I see these two errors, shown in the image here [ATTACH=CONFIG]33625[/ATTACH]
I get a similar debugger error when I run a script for synchronizing as well.  I was trying to learn from the simple start script sample given but seems to not work (nothing gets logged).  I tried running as administrator as well as the final posting commenter wrote and still no luck.  I have even changed the path to use UNC paths as well and still no luck. What do these 'bdb'. run error and the <module>(),line10:import arcinfo errors mean and how to fix them? No idea where to begin, any guidance or direction would help greatly.
Outcomes
