Error message while spatial joining
392
04-13-2014 10:02 PM
JagadeeshDutta
I am trying to join attributes from one table to another.But there is no common ID.So I am trying to use spatial join option.But not sure how to resolve that error.Can any one help in this regard. Please check the error message attached.
JAD
DanaNolan
Occasional Contributor III
This happens with GlobalID fields (GUID), which are used by programmers and in database replication. Assuming one side of your join has a GUID field, you may need to make a copy of the feature class without this field.
I would call this problem a bug; a join should be able to ignore GUID fields.
DaleHoneycutt
Are you writing the output to a shapefile?  They don't support GUID fields.  Write the output to a file geodatabase instead.
