chunjie
Eclipse Export SOE never succeed,using 10.2.1 sdk
Discussion created by chunjie on Apr 11, 2014
Latest reply on Apr 11, 2014 by chunjie
Hi:
     I am trying to update the sdk to 10.2.1, my eclipse version is eclipse-jee-kepler-SR2-win32-x86_64, my java sdk version is :     Java(TM) SE Runtime Environment (build 1.7.0_21-b11), Java HotSpot(TM) 64-Bit Server VM (build 23.21-b01, mixed mode).
     I created a simple SOAP SOE, with one method, and try to export the SOE to deploy to the arcgis server. but I kept getting this error "javac terminated with errors" as the flowing picture shows:
      [ATTACH=CONFIG]33036[/ATTACH]
      Does anyone facing the same problem?
      I checked the document for installation guide of eclipse plugin and find the flowing description:
      ArcGIS Eclipse plug-ins are compatible with the Eclipse IDE for Java Developers built using Eclipse 3.3. You may download Eclipse IDE  from Eclipse download site and install eclipse as suggested. For more information, refer Installing and using Eclipse IDE.
     So I switched to eclipse 3.3.2, and the problem still exists.
Outcomes
