I'm new to CityEngine and the CGA language. I'm trying to edit an existing CGA rule that came from the ArcGIS - 3D City site (http://www.arcgis.com/home/item.html?id=1a58cae727e24927be5a113e52557323). Currently the Street Construction.cga does not have a street parking rule so I've started the process. My goal is to check whether there is parallel parking on the left or right side of a road. I've edited the following sections to include the parallel parking but I'm not sure where in the code it places the texture between the outer lane and edge of pavement. I attached the cga file and any help is very appreciated.
I'm not sure I understand .. When you create the geometries with the 'Dynamic CityLayouts' system ( shapes ) and then create the actual models in CGA, why do you need to check ? What do you want to check precisely ?
