smenefee
Geocode Service - UICLSID
Discussion created by smenefee on Apr 1, 2014
Latest reply on Oct 7, 2014 by sacdou
When I check my ArcGIS Server logs, a lot of times I run across the following "Warning" message coming from our composite geocode service (that is being consumed by a flex web portal as well as a batch geocode routine):
Property 'UICLSID' cannot be modified (propMods parameter).
I've attached a screenshot of a search (most likely from the batch routine) and the subsequent warning.
It seems like it's benign because the geocoder has always worked just fine.  However, I'd like to get it out of my logs if I could.  Does anyone know how I might do that?  Any help would be appreciated, thanks!
Outcomes
