How to release LOCK FILE?
5976
9
03-05-2014 12:01 PM
YangLiu2
Hi all,
Recently, we published a GP Services. When running the GP Service on ArcMap, it works fine. However, when running it on Web Server. I got error like the screenshot: "esrijobfailed". We go to read the LOGS in ArcGIS Server Manager.
Sometimes, the error is "ExecuteError: ERROR 000871: Output table: Unable to delete the output".
Sometimes, the error is "ExecuteError: ERROR 999999: Error executing function. Cannot acquire a lock. Cannot acquire a lock. ERROR 010037: Output table D:\ArcGISData\ArcServerData\TxFIP\tools\ScratchWorkspace\scratch\scratch.gdb\tempUrbanStats could not be created".
Sometimes, it is "ERROR 999999: Error executing function. The table already exists. No spatial reference exists".
Sometimes, it is " ERROR 000464: Cannot get exclusive schema lock. Either being edited or in use by another application. Failed to execute (Delete)".
Besides, I check in the gdb folder. There are usually two lock files: _gdb.lock and tempStatsTable.lock. And they are not released after GP Services termination.
I also find that after the GP Service firstly executes, we wait several minutes and run the GP again, the GP works on Web server again though two lock files are still in gdb folder. Any thought? Thanks!
Best,
Yang
DorothyMortenson
Occasional Contributor II
Did you ever find a solution to this? I am running into something similar.
Works fine in ArcTools, create the GP Service, go to the web service and it creates a locked file.
I had thought that
del mxd (name of the mxd used)
del arcpy
would work, but it doesn't.
DorothyMortenson
Here is the code:
def make_map(wl_id, well_label_text, well_label_nbr, well_label_lat_dd , well_label_long_dd , x_coord , y_coord, trsqq_key , address_of_well ,  submitted_by , location_source  😞
    # ----------- IMPORTS ----------------------------------------------------------
    import datetime, sys, arcpy, os, shutil, time
    # PATHNAMES AND OTHER VARIABLES
    blah, blah
    # CREATE POINT
    spatialRef = arcpy.Describe(dataset).spatialReference
    if arcpy.Exists(temp_well_point):
        arcpy.Delete_management(temp_well_point)
        print "Old version of well point was deleted."
    ptx = float(x_coord)
    pty = float(y_coord)
    well_point = arcpy.Point(ptx, pty)
    pointGeometry = arcpy.PointGeometry(well_point, spatialRef)
    logfile.write("\n... Geometry of point is created...\n")
    arcpy.CopyFeatures_management(pointGeometry, temp_well_point)
    arcpy.AddField_management(temp_well_point, "MAP_LABEL", "TEXT", "", "", 20)
    map_label = "\"" + well_label_nbr + "\""
    arcpy.CalculateField_management(temp_well_point, "MAP_LABEL", map_label,   "PYTHON")
    # CREATE MAP
    # Process: Delete pre-existing png...
    if os.path.exists(well_location_map):
        os.remove(well_location_map)
    # .... Change the extent to the selected area ...
    df           = arcpy.mapping.ListDataFrames(well_mxd,"Layers") [0]
    newExtent    = df.extent
    newExtent.XMin, newExtent.YMin = xmin, ymin
    newExtent.XMax, newExtent.YMax = xmax, ymax
    df.panToExtent(newExtent)
    #... Add the Layer and Change the Cartography .....
    wellLayer = arcpy.mapping.Layer(well_layer)
    wellLayer.replaceDataSource(workspace_temp, "SHAPEFILE_WORKSPACE", wl_id)
    arcpy.mapping.AddLayer(df, wellLayer, "TOP")
    wellLayer.showLabels = True
    # change the text of the map
    for elm in arcpy.mapping.ListLayoutElements(well_mxd, "TEXT_ELEMENT"):
        if elm.text == "latitude_text":
            elm.text = lat_line
        if elm.text == "longitude_text":
            elm.text = long_line
        if elm.text == "trsqq_text":
            elm.text = trsqq_line
        if elm.text == "well_label":
            elm.text = well_label_line
        if elm.text == "address_of_well_text":
            elm.text = address_of_well_line
        if elm.text == "source_text":
            elm.text = location_source
    # ... refresh the map .....
    arcpy.RefreshActiveView()
    arcpy.mapping.ExportToPNG(well_mxd, well_location_map)
    # CLEANUP
    # ended up deleting the temp point to get rid of the locked files.
    # in other applications, I may not want to do this.
    del well_mxd
    del arcpy
SusanJones
Have you deleted all the objects that have been created in the script behind the GP Service?
ArcGIS Desktop takes care of this (mostly and usually) behind the scenes. But all objects in memory need explicit removal after use.
For example,
#create mxd in memory
mxd = arcpy.mapping.MapDocument(r'some fmxd')
#todo remove mxd
del mxd
If sounds like it is still hanging around in memory and that why it's status is lock.
Susan
SusanJones
can you post your code in the window
DorothyMortenson
See above.
In the cleanup section, I ended up deleting the temp point to get rid of the locked files. But in other cases, I may not want to do that.
SusanJones
Hi Dorothy
Geoprocessing Services have changed a bit since the ArcGIS Server 10.1 release. Your code works fine at the Desktop Tool level but when applied to ArcGIS Server is does not know where to find the output result datasets it has generated.
The code will need to be modified to use the ScratchFolder, ScratchGDB and the ScratchWorkspace  arcpy variable.
ArcGIS Server goes through and validates the code when the tool is published as a service. A new task is created each time the GP Service is called and a new (temporary) sets of Scratch Workspaces are created.
Did you get any warning messages when you published the tool? It will normally tell you it couldn't figure out the path to the data because it is not know to ArcGIS Server.
http://resources.arcgis.com/en/help/main/10.1/index.html#//001w00000047000000
Susan
DorothyMortenson
That may help me with another issue I have.
But I still don't understand why it locks the file.
DorothyMortenson
No there were not errors, warnings or messages.
SusanJones
I think it has locked the file because it didn't get cast as the result.
