How do I make some simple rectangles with some text next to it?
3933
02-24-2014 03:40 AM
AndyGreen
Hi all experts,
I know that this is probably very simple, but I can not figure out how I get drawn 2 rectangles on the map with some text next to it (see attached picture).
[ATTACH=CONFIG]31696[/ATTACH]
I've tried in the sandbox but nothing works, can anyone help?
The complete html code would be nice! 🙂
Thanks in advance
Sincerely,
Andy Green
JakeSkinner
Esri Esteemed Contributor
Hi Andy,
You can use the Draw and TextSymbol classes to achieve this.  Use a geometry service to find a point for placing a label inside or around the drawn polygon.  You can see an example here.
AndyGreen
Hi Andy,
Thanks a lot, Jake 🙂
But I don't get it? - and I don't know how to use "Edit Fiddle", sorry.
I don't want to "draw" with toolsbars or anything fancy, I just need some (probably just 10 lines of code) to put a static rectangle onto my map as I illustrated on the image I attached.
For example on Google Maps API, I would use this piece of code, and this works just fine!
There must be something similar I can use in the sandbox?
    var rectangle = new google.maps.Rectangle({
    strokeColor: '#FFFF00',
    strokeOpacity: 1.0,
    strokeWeight: 1,
    fillColor: '#FF0000',
    fillOpacity: 0.0,
    map: map,
    bounds: new google.maps.LatLngBounds(
      new google.maps.LatLng(40.32, 124.50),
      new google.maps.LatLng(40.26, 128.70))
Best 🙂 Andy
JakeSkinner
You will want to use the Graphic class to create the graphic and add it to your map.  Ex:
<!DOCTYPE html>
<html>
<head>
  <title>Create a Map</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
  <style>
    html, body, #mapDiv{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="http://js.arcgis.com/3.8/"></script>
  <script>
    var map;
    require([
        "esri/map",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleLineSymbol",
        "dojo/_base/Color",
        "esri/graphic",
        "esri/geometry/Polygon",
        "dojo/on",
        "dojo/dom",
        "dojo/domReady!"
    function(
        Map, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic,
        Polygon,
        on, dom
      map = new Map("mapDiv", {
        center: [-75.249, 38.485],
        zoom: 9,
        basemap: "streets"
      on(map, "load", addGraphic);
      var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
        new Color([255,0,0]), 2),new Color([255,255,0,0.25])
      function addGraphic(){
            var singleRingPolygon = new Polygon([[-75.77, 38.45], [-75.77, 38.7], [-75.11, 38.7], [-75.11, 38.45], [-75.77, 38.45]])
            var gra = new Graphic(singleRingPolygon, sfs);
            map.graphics.add(gra);
  </script>
</head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
AndyGreen
<!DOCTYPE html>
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script>
    var map;
    require([
        "esri/map",
        "dojo/_base/Color",
        "esri/graphic",
        "dojo/on",
        "dojo/dom",
        "dojo/domReady!"
    function(
        Polygon,
        on, dom
        zoom: 9,
        basemap: "streets"
  </script>
</head>
</body>
</html>
JUST PERFECT !!! - Thank you 1000 times 🙂
