Export rule packages, result in ArcScene
2095
02-03-2014 10:58 PM
Jelmervan_der_Veen
Hello everybody,
In City Engine 2013 I have created a rulefile that creates a forest from polygon shapes. I'm using the "scatter" and "FileRandom" functions. With the FileRandom function is used to  insert random  *.obj files from a folder. The rule file works well in CityEngine
Now I want to export the rulefile as rule package so I can open recreate the forest in ArcScene. The display of the locations of the trees is good,only the trees have no texture in ArcScene. See the difference in screenshot.
[ATTACH=CONFIG]31095[/ATTACH]
Anyone have an idea how I can fix it?
Jelmer
MatthiasBuehler1
Hi !
I got some answers on this.
It could be that you hit an internal memory limit in ArcScene.
Can you check only very few ( e.g. 5 ) trees and check if ArcScene displays them validly ? If they're not displayed nicely, can you open them in ArcGlobe ?
If also ArcGlobe does not show the trees nicely, it may be an exporter bug.
Either way, let me know.
Matt
