Thanks for creating a sample! Just what I needed 😃No worries about the handles....they aren't showing up because jsfiddle cannot access your images.Got it to completely hide but you will need to fix the container.To Fix:Remove the inline styling on 'slide-out-div' and 'slide-out-div1' (also remove the extra semi-colons).Change the styling with CSS as you see fit.<div class="slide-out-div"> <div id="innerTOC"> <!-- code here --> </div> </div> <div class="slide-out-div1"> <div id="innerTOC"> <!-- code here --> </div> </div>
*editHere's a jsfiddle:http://jsfiddle.net/7g4ta/6/Notes: - Changed background color on the handles so they can be seen in jsfiddle (see CSS classes)- Changed 'topPos' to 120px from 90px for 'slide-out-div1'- Removed inline styling from slide-out-div, slide-out-div1 and innerTOC divs (NOTE: please do not use the same ID for multiple divs)- Changed 'height: auto !important' on 'slide-out-div1'You will need to make a few more CSS changes to achieved your desired outcome.If you feel you have recieved a sufficient response, please mark a post as the answer and mark this thread as answered.Thanks!!!
