Shape integrity error
1372
12-18-2013 09:36 AM
EdwardGlover
New Contributor III
Polygons have been inadvertently deleted from a feature class (FC).  The records however still exists in the attribute table.  For example there is no polygon representing oid 14308 (see attached image) and when I try to select the record, it flashes blue and returns to no selection .  I cannot use the repair geometry tool because the FC is in an SDE environment.  I also cannot create a topology layer to address the issue because the FC is not in a feature dataset and when I try and copy the data into a feature dataset I am unsuccessful due to the shape integrirty error.  Unfortunatley this issue currently resides in the default version of the FC.
