swc000
Raster histogram x-axis values
Discussion created by swc000 on Nov 10, 2013
How do you change the values shown on the x-axis of a histogram for a raster (Properties > Classified > Classify)?
For example, the default values displayed along the x-axis for a DEM are scaled between the Min to Max elevations. You can toggle between Min-Max and Percent values by using the "%" button above the Break Values frame, but the axis values remain the same. Is there a way to switch the x-axis values to either scale? In image below, the axis shows the Min-Max scale, but toggled range is in percent.
[ATTACH=CONFIG]28990[/ATTACH]
Outcomes
