sle06
Using views with an ArcGIS 10.0 sde connection in ArcGIS 10.2
Discussion created by sle06 on Oct 25, 2013
Latest reply on Oct 29, 2013 by sle06
I've created a view(schema bound and indexed) for our ArcSDE 10.0. I've set permissions and everything works fine when I connect to the database in ArcDesktop 10.0 but when connecting to the database using ArcCatalog 10.2 I am having an issue. I can see the view I've created but I am not seeing the index that was created with it. When I look at this view using 10.0 it shows up as a table but when in using 10.2 it is still showing as a view. I am using the same connection properties for both.
The view was created in SQL Server 2005.
I've attached a screen shot of the 2 different properties that I see. The one on the right is from the connection with 10.2.
Thanks for any suggestions,
S
Outcomes
