Hi, I am using this code, and is perfect, but as I can do to get the points found appears.
I want to show the Locate points of interest of my map service in ArcGIS Server, but failed
[ATTACH=CONFIG]28592[/ATTACH]
I'm using google translate sorry
hopefully can guide me, thanks
<!DOCTYPE html> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } body { background-color:#FFF; overflow:hidden; font-family:"Trebuchet MS"; } #search { display: block; position: absolute; z-index: 2; top: 20px; left: 75px; } </style> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script> <script> dojo.require("esri.map"); dojo.require("esri.dijit.Geocoder"); var locatorUrl = "http://localhost:6080/arcgis/rest/services/localizador/GeocodeServer"; function init() { var map = new esri.Map("map", { //basemapUrl : "http://localhost:6080/arcgis/rest/services/Cementerio/MapServer", //center : [-120.45, 37.28], //long, lat //zoom : 10 }); var myGeocoders = [{ url : locatorUrl, name : "localizador" } ]; var geocoder = new esri.dijit.Geocoder({ map : map, autocomplete : true, arcgisGeocoder : false, geocoders: myGeocoders, value : 'buscar' }, "search"); geocoder.startup(); var imageParameters = new esri.layers.ImageParameters(); imageParameters.layerIds = [1]; layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/Cementerio/MapServer", { "imageParameters" : imageParameters }); map.addLayer(layer); } dojo.ready(init); </script> </head> <body> <div id="search"></div> <div id="map"></div> </body> </html>
