Hello !
I have a problem with duplicate items in the legend panel!
[ATTACH=CONFIG]27777[/ATTACH]
I have PointFeatureLayer as Shapefile in ArcMap. I had group these features by an attribute in the Menu :
Properties-Symboloy-Categories-Match to Symbols in a style
After that, i have published this as mapservice.
Have i choose the wrong settings in the Service Editor or is that a problem in my sourcecode?
Here is my Code from my featurelayer:
[HTML]// Feature Layer
var msFeatureLayer = new esri.layers.FeatureLayer("url",{
mode: esri.layers.FeatureLayer.MODE_SELECTION,
outFields: ["*"],
infoTemplate:new esri.InfoTemplate({
title:"<b>infos</b>",
content:"<b>Code:</b>${Code}<br/>"
displayOnPan:true,
visible:true,
opacity:1.0
});[/HTML]
And here i adding the layer to the map and to the legend:
[HTML]legendLayers.push({layer:msFeatureLayer,title:'Ms'});
map.addLayers([msFeatureLayer]);
// control when add a Layer to the map
dojo.connect(map,'onLayersAddResult',function(results){
// Activate all Features from a Feature Layer
showFromFeatureLayer(msFeatureLayer,"1=1");
// Legend init
new esri.dijit.Legend({
map:map,
layerInfos:legendLayers
},"legendDiv").startup();
// Add Checkboxes with label
dojo.forEach(legendLayers, function(layer){
var checkBox = new dijit.form.CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function(evt) {
var clayer = map.getLayer(this.value);clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
dojo.place(checkBox.domNode,dojo.byId("toggle"),"after");
dojo.place("<br />",dojo.create('label',{'for':checkBox.name, innerHTML:layer.title},checkBox.domNode,"after"),"after");
});[/HTML]
Thanks for your help!
