Hi, I am getting the error message designated in the title when trying to import a point shapefile with a few hundred points to a webmap in map viewer online. can you please explain this to me? I have attached the shapefile.
Thanks for the timely response timw1984 but unfortunately I am still having the same issue. Any other advice?
The problem is that your shapefile is Multipoint. You have to convert it to Point. You can do this with the Feature to Point tool. After converting to point I was able to import it to a web map.
I recommend what Tim said earlier, to project your data into Web Mercator (Auxiliary Sphere).
