andrade84
ADD / CALCULATE / ITERATE and EXPORT at Model Builder
Discussion created by andrade84 on Aug 26, 2013
Hi everbody.
Here I am again, asking for help :confused:
I'm trying to build a model at model builder and I don't know if it's possible.
I want to do the following steps:
Intersect two layers >>> Add a field in the resulting layer >>> calculate a expression in the just created field >>> select some register of the expression calculated, and finally >>> export the selected registers to a new layer.
Here's image of what I was trying. The problem is probably occuring after the ADD FIELD step, cause I can't set the just created field as a input in the CALCULATE FIELD step.
I  aprecciate any help. Thank's
[ATTACH=CONFIG]26995[/ATTACH]
Outcomes
