Increased C-drive volume now can't connect to my 'Site'
568
08-19-2013 05:14 AM
JoeFlannery
Occasional Contributor III
I had an ArcGIS for Server 10.1 instance built and running for months in AWS.  Yesterday, I increased the C-drive volume of my AWS Instance and now I cannot connect to my 'Site' in Server Manager.
I created a Snapshot of the old C-drive.
I created a larger volume from the old C-drive Snapshot.
I detached my old C-drive and D-drive volumes.
I attached my new larger C-drive volume then my original D-drive volume.
I remoted back into my instance and used Computer Management/Disk Management to extend my C-drive to the new space.
When I open ArcGIS Server Manager I am given the options to Create New Site or Join Existing Site.
Since I already have Server Directory and Config Store directories established, I chose Join Existing Site.
When I go through the process to Join my Existing Site, I get the error message "Server machine '10.191.73.212' does not participate in any Site" (see attached).
Has anyone else experienced this behavior and have any advice?
Thank you,
Joe
MikeSchonlau
Did your internal machine IP change? If so, you may need to update your HOSTS file. Is 10.191.73.212 the current private IP of your machine?
Mike S
JoeFlannery
Michael:
I was unable to fix my earlier server Site, so I killed it and started over.  Since it is a test machine and I did not have many services running, I did not suffer a large hit.
Thank you for your suggestion.  I will keep that in mind should this issue arise in the future.
