ebaiello
Feature Service - Local Copy for Editing could not be created - item not found
Discussion created by ebaiello on Aug 15, 2013
Latest reply on Sep 23, 2013 by JonnyGUK1
After successfully publishing a Feature Service with 10.1 that appears to function correctly, I am unable to Create a Local copy for editing via ArcMap - attached error. The service is editable via a java API  but does not work via ArcMap 10.1.
The error appears to be db related - "Item Not Found - Item Type :{........} The table was not found."
Any thoughts on what might be causing this behaviour? I am certain all permissions & privis for the AG4S account are correct as the service is published, looks correct, and can be edited over the web....
Thank you,
Eric
Outcomes
