sucinimad
KML layer looks different in arcgis vs google map
Discussion created by sucinimad on Jul 23, 2013
Latest reply on Jul 24, 2013 by kenbuja
I have a KML layer generated from a google map here: http://maps.google.com/maps/ms?ie=UTF8&hl=en&vps=2&jsv=344a&msa=0&output=nl&msid=209903690916272517145.000490409fc924e00e3ee
When used with google map API, it appears normal. When used with esri, there's a band of layer that goes across the map.
[ATTACH=CONFIG]26161[/ATTACH]
This is the code used to add the layer:
var kmlUrl = "http://maps.google.com/maps/ms?ie=UTF8&hl=en&vps=2&jsv=344a&msa=0&output=nl&msid=209903690916272517145.000490409fc924e00e3ee";
var kml = new esri.layers.KMLLayer(kmlUrl);
map.addLayer(kml);
I was wondering if you guys would have any ideas on what might have caused it. Thanks.
Outcomes
