arc 10  arc-hydro error 91 delineating
2946
07-23-2013 10:34 AM
JohnDudula
Hi I have been try in to run the swat model and been having trouble cause i been getting the same error over and over when i try to delineate in arc 10 using arc hydro.  I looked online and found the answer some were on this form but now i can't find it again. so could some tell me how to fix the error or tell me were the proper form is?
MarkBoucher
Occasional Contributor III
Using Arc Hydro, there is a point in the process where you put in the number of cells at which streams should start. This is the stream definition step. Maybe this is the process you need to go through. See link below my signature for several posts on Arc Hydro.
