Solved! Go to Solution.
Vansi,
I've also seen similar problems occur randomly on different machines, and including non-ArcGIS Runtime projects when using Eclipse.
I have a few suggestions:
- This may be obvious, but just in case, did you try the following?
- Check your Java Build Path > Order and Export settings and make sure that at least the ArcGIS for Android 10.1.1 is checked > "OK" > re-clean your project > rebuild > run. On my builds I make sure that the Android SDK is before the ArcGIS Runtime (in terms of the order)
- Android Tools > Fix Project Properties > Clean
- ArcGIS Tools > Fix Project Properties > Clean
- Note you can also add missing files under the Java Build Path > Libraries tab. See this StackOverflow page.
-Andy
Vansi,
-Andy
Vansi,
Awesome, glad you got it taken care of. If you have a moment, I have a few more questions that may help others on the forum.
>>However the problem was with the target device i was installing the app into.
Can you please clarify this, did the error you posted occur while trying to run the app on the emulator? Or, if you are referring to particular smartphone or table, please post the make, model and OS number?
>>This ArcGIS app doesn't run in the emulators especially the Intel x86-system emulators.
Did you try the steps listed here? http://blogs.esri.com/esri/arcgis/2012/05/02/arcgis-runtime-sdk-for-android-v1-1-supports-android-em...
-Andy
