hello,i use arcpy.mapping to export e map,code like this:
mxdPath = "C:/dev/temp/base.mxd"
mxd = arcpy.mapping.MapDocument(mxdPath)
...load fc from shapefile...
arcpy.MakeFeatureLayer_management(fc,fname)
addLayer = arcpy.mapping.Layer(fname)
arcpy.mapping.AddLayer(df, addLayer)
arcpy.env.extent = arcpy.Extent(XMin=minX,YMin=minY,XMax=maxX,YMax=maxY)
newExtent = df.extent
newExtent.XMin, newExtent.YMin = minX, minY
newExtent.XMax, newExtent.YMax = maxX, maxY
df.extent = newExtent
ExportToPNG(mxd, outputPath,df,
df_export_width=width,
df_export_height=height,
world_file=None,
resolution=dpi)
i publish it as a gpsrvice,to export png
and then i publish another mapservice with the same shape file
when i add both service on the flex,
the basemap use the service publish by mapservice.
the second layer use the gpservice result.
request with same extent,same size,
but the export image is not the same,i can't find the reason,can you help me?
