ODCostMatrix SOAP Request
1814
06-19-2013 11:07 AM
HernanB
Hello everybody!
I'm receiving:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
   <soap:Body>
      <soap:Fault>
         <faultcode>soap:client</faultcode>
         <faultstring>Unable to instantiate class for xml schema type: NAServerSolverParams</faultstring>
         <detail/>
      </soap:Fault>
   </soap:Body>
</soap:Envelope>
When I send the following the content in the attached file via SOAP
Do you have any idea or suggestion?
Thank you!
JamesBratton
NAServerSolverParams is an abstract type.  When creating an instance of it as SolverParams, you need to specify the type of NAServerSolverParams that you want to use.
Your request starts like this
<soapenv:Body>
      <ns:Solve>
         <SolverParams>
but it should be this instead
<soapenv:Body>
      <ns:Solve>
         <SolverParams xsi:type="NAServerODCostMatrixParams">
