jsn
Desktop Console Applicaiton does not close window in 10.1
Discussion created by jsn on Jun 11, 2013
Latest reply on Jul 12, 2013 by jsn
Hi all
I wrote a Desktop Console Application in 9.3 and it works fine.  Then I upgraded to  10.0 and it works fine too.
I copied the application  to a Windows server 2008R2 with ArcGIS 10.1 recompiled, etc, and now I have a problem when I run the .exe alone, the Console Window does not close, it stays open.
I am using VS 2010 VB.NEt and if I run the application from VS 2010 IDE it works fine, but running it as a stand alone program the Console Window does not close.
I am checking the code and commenting the following line:
      pFeatureClass = gputilities.OpenFeatureClassFromString(pathOutput)
the stand alone program works fine.
Anyone with a similar problem
  'ESRI License Initializer generated code.
        If (Not m_AOLicenseInitializer.InitializeApplication(New esriLicenseProductCode() {esriLicenseProductCode.esriLicenseProductCodeAdvanced}, _
        New esriLicenseExtensionCode() {})) Then
            Console.WriteLine(m_AOLicenseInitializer.LicenseMessage())
            Console.WriteLine("This application could not initialize with the correct ArcGIS license and will shutdown.")
            m_AOLicenseInitializer.ShutdownApplication()
            Return
        End If
        ' Initialize the Geoprocessor
        GP = New ESRI.ArcGIS.Geoprocessing.GeoProcessor()
        gputilities = New GPUtilitiesClass()
        ' Read App settings
        prefixOutput = System.Configuration.ConfigurationManager.AppSettings.Item("prefixOutput")
        prefixOutputOwner = System.Configuration.ConfigurationManager.AppSettings.Item("prefixOutputOwner")
        outputFC = System.Configuration.ConfigurationManager.AppSettings.Item("outputFC")
        ' FFeature class
        pathOutput = prefixOutput & prefixOutputOwner & outputFC
        ' create points
        Console.WriteLine("Start")
        Try
            '   pathOutput = SDE Feature Class where the program creates points
            Console.WriteLine("Create Points")
            ' CreatePoints()
            pFeatureClass = Nothing
        Catch ex As Exception
        End Try
        Console.WriteLine("End")
[ATTACH=CONFIG]25192[/ATTACH]
Outcomes
