naseltzer
Zonal Statistics Table over NetCDF to Raster, not completing zonal statistics
Discussion created by naseltzer on Jun 10, 2013
I have a NetCDF dataset which I'm importing into ArcMap 10.1 using the make NetCDF Raster Layer tool. I also have a polygon fishnet which I'm attempting to aggregate a number of different statistics to using the Zonal Statistics Table tool, followed by a join. My fishnet is constituted from 2892 polygon cells. The problem is that when I use the Zonal Statistics Table tool, it only calculates the values for 405 of those cells. In the image below, the cells which are calculated are colored in pink. You can see the remaining cells as well as the raster layer beneath. As you can see, it appears that the job is just stopping right in the middle for some reason. Does anyone understand what is happening?
[ATTACH=CONFIG]25188[/ATTACH]
Outcomes
