johnmdye
Split Field values into two new fields
Discussion created by johnmdye on Jun 5, 2013
I have a table being returned from the Network Analyst OD Cost Matrix...
[ATTACH=CONFIG]25021[/ATTACH]
I want to convert the result object to a GDB Table and I tried using this..
ODCM_Table = arcpy.na.Solve(outNALayer) #Solves the Origin-Destination Cost Matrix and produces the ODCM_Table
arcpy.TableToTable_conversion(ODCM_Table, workspace + "\Default.gdb", "ODCM") # Thought this should convert result to GDB Table
But it throws an error:
Runtime error Traceback (most recent call last): File "<string>", line 1, in <module> File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\conversion.py", line 1904, in TableToTable raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Rows: Dataset GPL0 does not exist or is not supported Failed to execute (TableToTable).
I thought maybe the cause of the error was the formatting of the result object being held on the 'ODCM_Table' variable, so I printed it to see what it returns...
print ODCM_Table
GPL0
No problem I can see there.
So how can I convert this result object to an actual table?
Outcomes
