I am in the process of setting up a new 64 bit server running ArcSDE 10.1 on SQL Server 2012 and have run into a little issue. When I open the geodatabase up in ArcCatalog I now see the SDE_compress_log as a table in the geodatabase. I noticed that it DOES NOT appear in the previous server. Within SQL Server management studio it is located in the same spot for both servers under the tables folder of the databases. How could I change where this log is stored so that when desktop ArcGIS users connect they don't have to see this table?
[ATTACH=CONFIG]25004[/ATTACH]
