taylorsb
Help with Logging
Discussion created by taylorsb on May 20, 2013
Latest reply on May 20, 2013 by jamesfreddyc
I am having some issues actually getting my python script to write out to a log file.  It is running to the point of the script that says "with open(rapLogFile, 'r') as f:" then I am getting a traceback error of "Traceback (most recent call last):
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 312, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\Documents and Settings\taylorsb\Desktop\Rec_Post_Log_Test.py", line 145, in <module>
    thisLogger.error('  ' + e.args[0])
TypeError: cannot concatenate 'str' and 'int' objects".  When I comment out that part of the traceback it is still telling me it does not like something about line 90.  Any help would be appreciated!  Here is the code:
import sys, arcpy, os, smtplib, logging, datetime, time
from logging.handlers import TimedRotatingFileHandler
fullPath = r'\\10.1.64.36\Indiana\Steve_WIP\Nightly_Log_Files'
##thisPath = os.path.dirname(fullPath)
##thisFile = os.path.basename(fullPath)
thisName = r'\\10.1.64.36\Indiana\Steve_WIP\Nightly_Log_Files'
##cfgFile = thisName + '.cfg'
logFileInfo = thisName + '-Info.log'
logFileDebug = thisName + '-Debug.log'
chFormatter = logging.Formatter('%(funcName)-24s: %(levelname)-8s %(message)s')
fhFormatter = logging.Formatter('%(asctime)-2s %(funcName)-24s %(levelname)-8s %(message)s', '%m/%d/%Y %I:%M:%S %p')
ch = logging.StreamHandler()
ch.setLevel(logging.DEBUG)
ch.setFormatter(chFormatter)
fhInfo = logging.FileHandler(logFileInfo, 'w')
fhInfo.setLevel(logging.INFO)
fhInfo.setFormatter(fhFormatter)
fhDebug = TimedRotatingFileHandler(logFileDebug, when='D', interval=30, backupCount=13)
fhDebug.setLevel(logging.DEBUG)
fhDebug.setFormatter(fhFormatter)
global thisLogger
thisLogger = logging.getLogger('ThisLogger')
thisLogger.setLevel(logging.DEBUG)
thisLogger.addHandler(ch)
thisLogger.addHandler(fhInfo)
thisLogger.addHandler(fhDebug)
thisLogger.info('* * *  B E G I N  ' + fullPath + '  * * *')
thisLogger.info('Begin function\n')
rapLogFile = thisName + '-ReconcileAndPost.log'
rapLogFile = fullPath + '\\' + rapLogFile
rLogFile = thisName + '-Reconcile.log'
rLogFile = fullPath + '\\' + rLogFile
West_Versions=arcpy.ListVersions("Database Connections\\INAW_West_GISADMIN_10.sde")
i=2
targetVersion = 'West_Versions[i]'
try:
    # Get start time
    start = datetime.datetime.now()
    thisLogger.info('  Begin function')
    # Get a list of the versions that match the versionFilter
    thisLogger.debug('  Getting a list of the versions to reconcile and post...')
    versionList = []
    ##for version in arcpy.ListVersions("Database Connections\\INAW_West_GISADMIN_10.sde"):
        ##if version.name.upper().split('.')[1] == versionFilter:
            ##versionList.append(version.name)
            ##thisLogger.debug('  - ' + version.name)
        ##thisLogger.info('  Found ' + str(len(versionList)) + ' versions to reconcile and post.')
    # Remove the log files (from previous runs) if they exist
    if os.path.isfile(rapLogFile):
        os.remove(rapLogFile)
    if os.path.isfile(rLogFile):
        os.remove(rLogFile)
    # Execute the ReconcileVersions tool.
    while i <=len(West_Versions)-1:
        thisLogger.debug('  Reconciling and posting ' + West_Versions[i] + '...')
        print "Reconciling: " + West_Versions[i]
        arcpy.ReconcileVersion_management("Database Connections\\INAW_West_GISADMIN_10.sde", West_Versions[i], West_Versions[1], "BY_OBJECT", "FAVOR_TARGET_VERSION", "LOCK_AQUIRED", "ABORT_CONFLICTS", "POST")
        i=i+1
        print "Reconcile and Post Production Version Complete"
    print "Reconciling: " + West_Versions[1]
    arcpy.ReconcileVersion_management("Database Connections\\INAW_West_GISADMIN_10.sde", West_Versions[1], West_Versions[0], "BY_OBJECT", "FAVOR_TARGET_VERSION", "LOCK_AQUIRED", "ABORT_CONFLICTS", "POST")
    print "Reconcile and Post QC Version Complete"
    # Open the log file and write the contents to thisLogger
    thisLogger.info('  Results of Reconcile and Post:')
    thisLogger.info(' ')
        lines = f.read().splitlines()
    f.close
    for line in lines:
        thisLogger.info('    ' + line)
    # Reconcile all the child versions with the parent to pull all the edits down to the child versions
    thisLogger.debug('  Reconciling changes in ' + targetVersion + ' to the posted versions...')
    print "Starting Reconciling Only Operation"
    arcpy.ReconcileVersion_management("Database Connections\\INAW_West_GISADMIN_10.sde", West_Versions[1], West_Versions[0], "BY_OBJECT", "FAVOR_TARGET_VERSION", "LOCK_AQUIRED", "ABORT_CONFLICTS", "NO_POST")
    print "Reconcile Only QC Version Complete"
    i=2
        thisLogger.debug('  Reconciling changes in ' + West_Versions[1] + ' to ' + West_Versions[i])
        arcpy.ReconcileVersion_management("Database Connections\\INAW_West_GISADMIN_10.sde", West_Versions[i], West_Versions[1], "BY_OBJECT", "FAVOR_TARGET_VERSION", "LOCK_AQUIRED", "ABORT_CONFLICTS", "NO_POST")
        i=i+1
        print "Reconcile Only Production Versions Complete"
    thisLogger.info('  Results of Reconcile:')
    with open(rLogFile, 'r') as f:
    f.close
    for line in lines:
    # Append the contents of logFile2 to logFile1
    thisLogger.debug('  Appending the Reconcile log file to the Reconcile and Post log file...')
    with open(rapLogFile, 'a') as f1:
        with open(rLogFile, 'r') as f2:
            f1.write('\n' + f2.read())
    # Email a log to the rapDestination users:
    ##thisLogger.debug('  Sending email...')
    ##sendEmail(mailServer, logFile1, sender, destination, subject)
    ##thisLogger.info('  Sent "' + subject + '" email.')
    # Get end time and calculate the elapsed time
    elapsedTime = getElapsedTime(start)
    thisLogger.info('  --[Function Time: ' + elapsedTime + '] End function normally\n')
except Exception as e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    thisLogger.error('    Line %i' % tb.tb_lineno)
    thisLogger.info('  End function with ERROR\n')
Outcomes
