vestlink
Lines to follow layer boundaries
Discussion created by vestlink on May 7, 2013
Latest reply on May 8, 2013 by vestlink
Hi.
I have a polygon with a number of GPS-points inside.
I have used Analysis Tools -> Extract -> Clip in order to only include the point that fall within a given polygon.
I have used the Point to Line feature and then Split the line at vertices.
But the thing i have noticed is that some of the lines are connected through the polygon boundaries instead of following the boundary if intersected.
Is there a way to connect the points as describes above and have the line follow the polygon boundary if it lies between the two points?
Attached is a pdf of an example of the problem.
Im using ArcMap 10.1
[ATTACH=CONFIG]24122[/ATTACH]
Best regards,
Nicolai
Outcomes
