AnsweredAssumed Answered
Code won't run in IE8
Question asked by jwhayes76 on May 3, 2013
Latest reply on May 6, 2013 by jacobsj
For some reason my code wil not run in our version of IE8.  I combined the Find and Identify code samples to make this app.  Both the Find and Identify samples will work by themselves in IE8, but not my code that combines the two.  Any help would be great since most of our employees use IE.
Here's the version info for IE:
[ATTACH=CONFIG]24011[/ATTACH]
And here's my code:
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta http-equiv="X-UA-Compatible" content="IE=7, IE=8, IE=9, IE=10">     <!--The viewport meta tag is used to improve the presentation and behavior of the samples        on iOS devices-->     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>Pending Case Files</title>      <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css">     <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dojox/grid/resources/Grid.css">     <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dojox/grid/resources/claroGrid.css">     <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css">           <style>       html, body { height: 100%; width: 100%; margin: 0; padding: 0; }     </style>      <script>var dojoConfig = { parseOnLoad:true }</script>          <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script>          <script>       dojo.require("esri.map");       dojo.require("dojox.grid.DataGrid");       dojo.require("dojo.data.ItemFileReadStore");       dojo.require("esri.tasks.find");       dojo.require("dijit.layout.BorderContainer");       dojo.require("dijit.layout.ContentPane");       dojo.require("dijit.form.Button");       dojo.require("esri.dijit.Popup");       dojo.require("esri.dijit.InfoWindow");              var findTask, findParams;       var map, center, zoom;       var grid, store;       var identifyTask, identifyParams;        function init() {                      //setup the popup window          var popup = new esri.dijit.Popup({           fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,                new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]))         }, dojo.create("div"));                  dojo.connect(grid, "onRowClick", onRowClickHandler);          center = [-123.000, 45.487];         zoom = 11;                  map = new esri.Map("map",          {            basemap: "streets",           center: center,           zoom: zoom,           infoWindow: popup,         });                    var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mtbachelor.co.washington.or.us/arcgis/rest/services/joe/caseFiles_poly/MapServer",          {opacity:.7});          map.addLayer(landBaseLayer);          //Create Find Task using the URL of the map service to search         findTask = new esri.tasks.FindTask("http://mtbachelor.co.washington.or.us/arcgis/rest/services/joe/caseFiles_poly/MapServer/");          dojo.connect(map, "onLoad", function() {           //Create the find parameters           findParams = new esri.tasks.FindParameters();           findParams.returnGeometry = true;           findParams.layerIds = [0];           findParams.searchFields = ["CPO","NUMBER_KEY","FIRST_NAME"];           findParams.outSpatialReference = map.spatialReference;           console.log("find sr: ", findParams.outSpatialReference);           mapReady(map);         });       }        function doFind() {         //Set the search text to the value in the box         findParams.searchText = dojo.byId("caseFile").value;         findTask.execute(findParams,showResults);       }        function showResults(results) {         //This function works with an array of FindResult that the task returns         map.graphics.clear();         var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5]));          //create array of attributes         var items = dojo.map(results,function(result){           var graphic = result.feature;           graphic.setSymbol(symbol);           map.graphics.add(graphic);           return result.feature.attributes;         });                  //Create data object to be used in store         var data = {           identifier: "NUMBER_KEY",  //This field needs to have unique values.  Change to NUMBER_KEY after dissolved.           label: "NUMBER_KEY", //Name field for display. Not pertinent to a grid but may be used elsewhere.           items: items         };           //Create data store and bind to grid.         store = new dojo.data.ItemFileReadStore({ data:data });         var grid = dijit.byId('grid');         grid.setStore(store);          //Zoom back to the initial map extent         map.centerAndZoom(center, zoom);       }        //Zoom to the parcel when the user clicks a row       function onRowClickHandler(evt){         var clickedTaxLotId = grid.getItem(evt.rowIndex).NUMBER_KEY;         var selectedTaxLot;          dojo.forEach(map.graphics.graphics,function(graphic){           if((graphic.attributes) && graphic.attributes.NUMBER_KEY === clickedTaxLotId){             selectedTaxLot = graphic;             return;           }         });         var taxLotExtent = selectedTaxLot.geometry.getExtent().expand(7);         map.setExtent(taxLotExtent);       }       function mapReady(map)       {        dojo.connect(map,"onClick",executeIdentifyTask);        //create identify tasks and setup parameters         identifyTask = new esri.tasks.IdentifyTask("http://mtbachelor.co.washington.or.us/arcgis/rest/services/joe/caseFiles_poly/MapServer");                identifyParams = new esri.tasks.IdentifyParameters();        identifyParams.tolerance = 3;        identifyParams.returnGeometry = true;        identifyParams.layerIds = [0];        identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;        identifyParams.width  = map.width;        identifyParams.height = map.height;       }              function executeIdentifyTask(evt)        {         identifyParams.geometry = evt.mapPoint;         identifyParams.mapExtent = map.extent;                 var deferred = identifyTask.execute(identifyParams);          deferred.addCallback(function(response)            {                // response is an array of identify result objects               // Let's return an array of features.           return dojo.map(response, function(result)            {             var feature = result.feature;             feature.attributes.layerName = result.layerName;             if(result.layerName === 'Pending Case Files')             {              console.log(feature.attributes.NUMBER_KEY);              var template = new esri.InfoTemplate("", "Case Number: ${NUMBER_KEY} <br/>CPO: ${CPO} <br/> Class: ${CLASS} <br/> Type: ${SUB_TYPE} <br/>Comment Period Ends: ${EndCommentDate} <br/> <br/> Description: ${DESCRIPTION} <br/> <br/> Applicant: ${NAME}");              feature.setInfoTemplate(template);             }              return feature;           });         });                 // InfoWindow expects an array of features from each deferred         // object that you pass. If the response from the task execution          // above is not an array of features, then you need to add a callback         // like the one above to post-process the response and return an         // array of features.         map.infoWindow.setFeatures([ deferred ]);         map.infoWindow.show(evt.mapPoint);       }       dojo.ready(init);     </script>   </head>   <body class="claro">      <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"  style="width:100%;height:100%;margin:0;">     <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:80px;">        Case File, CPO, or Applicant: <input type="text" id="caseFile" size="25"  value="CPO" />       <button data-dojo-type="dijit.form.Button"  data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>         Search</button>     </div>     <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane" style="border:1px solid #000;"></div>    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">        <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid"  id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'10px'">       <thead>         <tr>           <th field="NUMBER_KEY">Case File</th>           <th field="CPO">CPO</th>           <th field="NAME" width="100%">Applicant</th>          </tr>       </thead>      </table>       </div>   </body> </html>
Thanks!
Outcomes
