ginomellino
Export Featureclass to Shapefile (Multiple) fails in 10.1.
Discussion created by ginomellino on Apr 21, 2013
Latest reply on Mar 2, 2014 by nidhinkn
Hi All,
I am trying to export a number of FGDB featureclasses to shapefiles in ArcCatalog but I am receiving the errors attached in the .txt. I right click on the GDB > Export > to Shapefile Multiple. I then fill in the output folder (which is d:\_GINO's\Planning Geodatabase\Planning Geodatabases\Custom Clips\LockyerValleyRC_20130419\Shapefile) and hit run and it fails. I noticed I cannot see any mention of the path I entered into the tool in the output error message. I did the exact same thing on a machine running ArcGIS 10 and it worked perfectly. Am I doing something wrong in 10.1 or is this a bug?
Thanks in advance
Gino
Outcomes
