Calculating fields - add start and end coordinates of line features to table
3979
10
04-16-2013 01:41 AM
AlexanderPichlmayr
Hello everybody,
Since a wile I am serching a way to solve a problem but cant get to any result.
What I want to do is to add koordinates of the startpoint and endpoint of a line-feature to its attribute table.
In my project I have to traw a great number of lines (representing power grid) so I manually added 4 fields (StartX, StartY, EndX, EndY). Is there any toold in arc toolbox that can help me calculate the koordinates for those 4 fields. Manually adding the data would be very time consuming. For better understanding i attached a photo with a sample of the grid (green line) and its attribute table.
Thanks for any kind of help
Alex
JoeBorgione
Right click on one of the field headings and select calculate geometry.  You'll be presented with a a pull down to select what you want to calculate.
JoeBorgione
AlexanderPichlmayr
Very good thanks a lot. That helps calculating the start and endpoint of a line-feature. Is there also a way to generate coordinates of vertex points?
JoeBorgione
Found this with a google search (with apologies to bing users...)
AlexanderPichlmayr
Hey thanks for the link. I tryed it already but it seems the tool does not work on arggis 10. (tool is from 2006). When I use it it shows up with the error " no module named win32api found failed to execute". I have Python 2.6(.5) installed and tryed with downloeading the extentions already -> no improvement! Dont really know what elese I can try!?
RobertPotter
I have a similar problem but I need to put the calculation of the coordinates (start and end of a line) into a model or script so it can be run on a regular basis.
Any clues?
RichardFairhurst
MVP Honored Contributor
Any clues?
It has to be done as a Python9_3 Field Calculation (at least at 10.0 and up) connected to a layer created with the Make Layer tool (not a feature class stored on disk, which is the normal output of most tools).  It is a simple calculation:
!Shape.FirstPoint.X! - does the Start/From end X coordinate
!Shape.FirstPoint.Y! - does the Start/From end Y coordinate
!Shape.LastPoint.X! - does the End/To end X coordinate
!Shape.LastPoint.Y! - does the End/To end Y coordinate
M and Z can be substituted for X or Y above, and Centroid can be used instead of FirstPoint/LastPoint to get the midpoint of the line.  http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000004m000000
RobertPotter
Thanks but it didn't work, well it did for a while then I got this after nearly 3 minutes
Start_X !Shape.FirstPoint.X! PYTHON_9.3 #
Start Time: Thu May 16 12:00:07 2013
ERROR 000539: Error running expression: GPVARIANTOBJECT0.FirstPoint.X
  File "<expression>", line 1, in <module>
SystemError: error return without exception set
The index was either too large or too small.
Failed to execute (Calculate Field).
Failed at Thu May 16 12:02:50 2013 (Elapsed Time: 2 minutes 43
What does it mean?  Essentially what you told me was correct and it worked a bit then stopped!!
It did 1970 of the 2843 in the file
[ATTACH=CONFIG]24353[/ATTACH]
RobertPotter
Ah overall thank you!
The problem above I have found out is on the client end (ie. my machine) basically it just ran out of memory.  I have now freed some memory and it works fine.
RobertPotter
Oh well as would be the case I spoke too soon.  Initially, it did finish but when I actually reviewed the results It had only calculated the coordinates for the first 1970 records (Start_X, Start_Y, End_X, End_Y) ????
So to check that result I tried to redo it but this time ArcMap CRASHED!!!  It asked if I wanted to send an error report to ESRI and I said yes, why not?
Then comes the funny bit....
...then would you believe it that Crashed also!!!
[ATTACH=CONFIG]24354[/ATTACH]
So really it is back to my original question ... how do I do this?????
