Linear Line of Sight of given elevation (not DTED's elevation)
820
03-27-2013 10:03 AM
oyleiste
Hello
I'm able to get linear line of sight of two points and draw visible and invisible areas like this: [ATTACH=CONFIG]23005[/ATTACH]
Well, is there any way to give observer's Z (elevation) and get line of sight of that point with given Z (not the elevation in DTED)? Imagine that I want to get LLOS of a helicopter that abviously it's elevation is greater that DTED's elevation of that point.
Or it's only possible with DTED elevations? Any idea?
Thank you
Regards
NeilClemmons
Regular Contributor III
Set the Z value for the point (IPoint.Z) to the elevation value you want to use.  Make sure the point is z-aware first (IZAware.ZAware = true).
NeilClemmons
JasonPike
Hello
Thank you
Regards
Instead of +1 on the line below, could you not just add the distance between the helicopter and the surface?
 // observer is 1m (MA start point offset) above the ground.
observer.Z = rsc.GetElevation( observer )+1;
oyleiste
Thank you Neil & ScJpike
You're great 🙂
