jfrankjr
Patchy Polygon
Discussion created by jfrankjr on Mar 21, 2013
Latest reply on Mar 26, 2013 by MBuehler-esristaff
I'm having trouble with polygon fill appearing patchy when rendered either with a color or image and aligned (align shape to terrain) to a terrain that has an image draped on it.  It appears as though part of the image is falling under the surface .  (see attached)  I tried aligning the terrain to shape with only a slight improvement.
Items of note:
1. the terrain and the image are the same extent.
2. portions of the outside boundary of the terrain are 0 value.  it was derived from contours that were clipped.  The range of the height values is from 0 to 679 with all the non-zero values falling between 579 and 679.
3. none of the features on this polygon layer fall outside of the area of non-zero value terrain
Has anyone had similar issues?  I'm actually looking to bring in many more polygon layers to cover a good portion of the terrain.
Jim
Outcomes
