The function ID is out of range
705
03-10-2013 08:14 AM
ArielLomes
New Contributor III
I'm having a problem with labeling parcels which are stored in a feature class inside a feature dataset on an 9.3 sde database, on MS SQL 2008 R2.
Whenever I zoom to the extent that the labels are set to appear, I get the following error:
[ATTACH=CONFIG]22499[/ATTACH]
The parcels themselves were created in ArcGIS Desktop 10.1, but we still have ArcSDE 9.3 installed in my organization.
The problem only occurs on that specific feature class. At first I managed to make it disappear by disabeling the maplex engine, but the problem returned after few times I opened and closed the MXD document.
Can anyone think of a solution?
Ariel.
WaelYahya
Please sendme a sample data to wael.yahya@gistec.com
JonathanQuinn
Esri Notable Contributor
Do you have joins set up in that mxd?  Can you recreate the MXD from scratch to see if the problem is reproducible?
ArielLomes
New Contributor III
Yes, I have a join. When I remove the join, the problem disappears.
I will try to recreate the MXD to see if it's reproducible.
ArielLomes
New Contributor III
Still the same problem now in another project, with exactly the same error after a join is done with a table.
