estipe
Create concave line between to points?
Discussion created by estipe on Feb 26, 2013
Latest reply on Mar 10, 2013 by dlee-esristaff
I am trying to create a concave line (beziel or multiple straight-line segments) between two points. I have used the "Point to Line" tool successfully to get a straight line (red in graphic), and also buffered around a point and turned that into a polyline (purple in graphic). However, for my purposes I need a line that bends inward between the two points, not straight or outward (green in graphic).
Each of this lines is being created at the intersection of lines, and there is an intersection point, if that helps. Essentially I want to bend  the straight line inward, if only a small amount.
I am hoping that a tool or series of tools will do this, as the dataset that I am working with is much too large to do by hand.
eric[ATTACH=CONFIG]22178[/ATTACH]
Outcomes
