Minimum Spanning Tree
1624
02-13-2013 08:24 PM
JohnLaycock
I have a set of dots, the green dots. I want to connect them all to the small blue dot, using the smallest distance. [ATTACH=CONFIG]21779[/ATTACH]
The lines can be anywhere, and there can be as many lines as necessary. Accordingly, I don't have a network file, just dots. It is either a minimum spanning tree problem.
Short of manually hacking it out, I have no idea how to do this.
John
DavidWilliams
Hi John,
ET GeoWizards can do this, see:
http://www.ian-ko.com/ET_GeoWizards/UserGuide/spiderDiagramAttributeLink.htm
Need to buy a licence though.
Thinking differently, could you not use "XY To Line (Data Management Tools > Features)" using the xy for all the green dots as your "start" and the xy of your blue dot as your "end".
Dave
