Script tool to transfer the ???Add??? - ???Delete??? tables (Delta Tables) into the base tabl
514
02-04-2013 12:31 AM
JamalNUMAN
Legendary Contributor
Script tool to transfer the ???Add??? - ???Delete??? tables (Delta Tables) into the base table,
I have been looking for a SCRIPT TOOL that transfer the content of the ???Add??? ???Delete??? into the base table (business table) but had no luck. This script is supposed to make both ???Add??? - ???Delete??? tables to be empty (no records).
[ATTACH=CONFIG]21388[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
AnthonyGiles
Jamal,
Essentially what you are after is performing a compress on the database:
http://resources.arcgis.com/en/help/main/10.1/index.html#/The_geodatabase_compress_operation/003n000...
This can easily be done by a peice of python script:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000000p000000
Regards
Anthony
JamalNUMAN
Jamal,
Regards
Anthony
Many thanks Anthony
As I have very little experience is scripting and building script tool then I�??m kindly looking for an integrated Script Tool for an end user.
All the best
Jamal
Jamal Numan
AnthonyGiles
Jamal,
Have a look at the help on creating script tools:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001500000006000000.htm
Regards
Anthony
JamalNUMAN
Jamal,
Regards
Anthony
thank you Anthony,
best
Jamal
Jamal Numan
