ArcPy, Determine what version an MXD is?
9399
12
08-02-2010 02:19 PM
RandyKreuziger
Occasional Contributor III
I have an ArcPy python script that replaces data sources.  Right now I'm saving out the MXDs as 9.3
but ideally I want to save the repaired version out in the same version of ArcGIS that the original is in.  Is there a way to do this?
If I don't specify the version my 9.3 mxds are saved out in version 10.
WilliamCraft
MVP Regular Contributor
I know this is an old thread, but here is some code I wrote to do the trick.  It can be incorporated into a loop for multiple MXDs.
import os, sys, arcpy, re
mxdFile = "C:\\temp\\map_document.mxd"
mxd101 = '10.1' + u'\u0013'
mxd102 = '10.1' + u'\u0013'
mxd103 = '10.3' + u'\u0014'
mxd104 = '10.4' + u'\u0015'
mxd105 = '10.5' + u'\u0016'
mxd106 = '10.6' + u'\u0017'
mxdList = [mxd101, mxd102, mxd103, mxd104, mxd105, mxd106]
result = []
with open(mxdFile, 'rb') as mxd:
   fileContents = mxd.read().decode('latin1')
   removedChars = [x for x in fileContents if x not in [u'\xff',u'\x00',u'\x01',u'\t']]
   joinedChars = ''.join(removedChars)
   for m in mxdList:
   location = joinedChars.find(m)
   if len(joinedChars[location:location+4]) > 0:
   result.append(joinedChars[location:location+4])
   print result[0]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DavidWynne
Hi kreuzrsk,
Yes, you can save out a map document to a different version using the saveACopy method on the MapDocument class.  The last argument is a version keyword.
>>> mxd.saveACopy("c:/output/base_93.mxd", "9.3")
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/MapDocument/00s30000000n000000/
-Dave
RandyKreuziger
Thanks but I know that already.  I need to save the MXD out to the same version of ArcGIS.  So if it's 9.3 I want to save to 9.3 but if it is 9.2 it needs to be saved as 9.2.  I notice that if you leave out the version keyword it upgrades the MXD to 10.0.
DavidWynne
No, not possible in Python in ArcGIS 10 to tell what release a mapdocument is currently saved as (I'm told possibly at 10.1)
-Dave
LinkElmore
New Contributor III
Is is possible to determine .mxd version from within ArcMap itself?  It's not listed in Map Document Properties (I'm using v10.0), where I thought it should be.
RandyKreuziger
-Dave
Dave,
  Assuming you're still out there do you know if this got added to 10.1?  I really need that able in a script I'm writing that strips out broken map service datasources.
MichaelVolz
Esteemed Contributor
Can anyone from ESRI answer this question?
I am currently running a similar script in v10.0 where it is not possible.  Once this script has processed all my organization's mxds and lyr files, I will be upgrading my enterprise GIS environment to v10.2.  I will need to run this script again in the v10.2 environment when my organization upgrades our SDE Oracle database from 11g to 12c, so this capability would be useful if it is now available at v10.2.
DavidWynne
Dave,
Alas, no.
I did see this strategy listed under the answer section that seems to hold though: http://gis.stackexchange.com/questions/62090/arcpy-method-to-determine-arcmap-document-version
MikeMacRae
Alas, no.
That's a very clever solution. Very useful!
WilliamCraft
result = []
   for m in mxdList:
