ArcGIS 10.1:Using XYZ coordinates to do MakeXYlayer-Runtime Error 000732. Why?
784
5
01-22-2013 05:05 AM
ScottChang
Hi all,
I have the following Excel .xls file:
ID    Pt_ID        X                 Y               Z
1     BH1          -76.301725   39.392986    0.1
2     BH2          -76.300981   39.392928    0.2
3     BH3          -76.301694   39.392611    0.3
9     BH9          -76.331157   39.396452    0.9
10   Well1        -76.332654    39.395984   1.1
I executed the following Python-ArcPy script:
# import system modules
import arcpy
from arcpy import env
# Set environment settings
# env.workspace = r"C:\TEMP\BS_Test.gdb"  # New!!!
try:
    # Set the local variables
    # in_Table = "firestations.csv"
    tb = r"C:\TEMP\WritingGeometries\ApgRImmrpWGS.xls\ApgRImmrpWGS$"
    xc = "X"
    yc = "Y"
    zc = "Z"
    out_Layer = "Pointlocations_layer"
    saved_Layer = r"c:\TEMP\APGriMMRPBHsWell.shp" # not .layer!!!
    # Set the spatial reference
    # spRef = r"Coordinate Systems\Projected Coordinate Systems\Utm\Nad 1983\NAD 1983 UTM Zone 11N.prj"
    spRef = r"Coordinate Systems\Geographic Coordinate System\World\WGS 1984"
    # Make the XY event layer...
    arcpy.MakeXYEventLayer_management(tb, xc, yc, out_Layer, spRef)
    # Print the total rows
    print arcpy.GetCount_management(out_Layer)
    # Save to a layer file
    # arcpy.SaveToLayerFile_management(out_Layer, saved_Layer)
    arcpy.CopyFeatures_management(out_Layer, saved_Layer) # New!!!
except:
    # If an error occurred print the message to the screen
    print arcpy.GetMessages()
in my newly installed ArcGIS 10.1 and I got Error 000732 - see the attached file for detals.
Please kindly help and tell me where I made mistakes and how to resolve this problems.
Scott Chang
AdamGuo
You might have the same problem as I had. Are you running 64bit?
Try and create a batch file: Change C:\YourScriptLocation.py to the location of your script. And run the batch file.
C:\python27\ArcGIS10.1\python.exe C:\YourScriptLocation.py
ScottChang
Hi Adam,  Thanks for your nice response.
I used to execute the Python-ArcPy scripts in the Python Window of ArcGIS 10.0 before.  I just had the ArcGIS 10.1 installed recently. I don't know the answer of your question regarding to: Are you running 64 bits? I guess my Computer Team installed the 32 bits of ArcGIS 10.1 in my "Windows 7" PC that is part of Microsoft NT 4 LAN System.  I just "LOAD" the script to the Python Window of ArcMAP (.mxd) of my new ArcGIS 10.1  to run.   I saw the following new thing in my ArcGIS 10.1:  C:\Users\e1enxshc\Documents\ArcGIS\Default.gdb.  I have no ideas about this C:\Users... folder!!??   I don't understand your Code: C:\python27\ArcGIS10.1\python.exe C:\YourScriptLocation.py.  Could you please explain what it is for me?
Please help and respond again.
Scott Chang
AdamGuo
It's probably easier if you read the thread below. I ran and posted the same error you had and started that thread. The solution should be in there for you.
http://forums.arcgis.com/threads/75735-Make-XY-Event-Layer-in-Python-Crashes-But-Not-in-Model-Builde...
ScottChang
Hi Adam,
I broght both the Data file and the Python script to the same C:\Temp folder and used the "Start" => ArcGIS\ Python 2.7.2\IDLE(Python GUI) place to execute my Python-ArcPy script.   I got the same Error 000732 - see the newly attached file for details. On the top of this Error Message, I saw "Python 2.7.2 (default, Jan 12 2011, 14:24:46) [MSC v.1500 64 bit (AMD64)] on win32" - Does it mean it runs on 64 bit?  Please help and respond on this strange error.
Scott Chang
ScottChang
Hi Adam and new ArcGIS 10.1 Users,
Per ESRI Technical Support, "Python 2.7.2 (defult, Jan 12, 14:24:46) [MSC v.1500 64 bit (AMD64)] on win32" shown in the IDLE Python (GUI) was wrong in my ArcGIS 10.1 installed originally. My wrong ArcGIS 10.1 installed originally was deleted and a new ArcGIS 10.1 was downloaded from an ESRI source and installed in my "Windows 7" PC.  I ran my old Python-ArcPy script on the new IDLE Python (GUI) that shows "Python 2.7.2 (default June 12, 2011.15:00:59) [MSC v.1500 32 bit (Intel)] on win 32" successfully without any errors!!!!  I just want to tell you and new ArcGIS 10.1 Users this important thing in executing the Python-ArcPy scripts for Make XY Event Layer.
Scott Chang
