thanks. john gravois.im not sure exactly what you're trying to accomplish. but the intersect operation exposed by an ArcGIS Server geometry service provides an approach to compare geometries in a similar way to what you can do with AO on the desktop.
I use "geometryService.intersect()" follow
dojo.connect(m_selectionToolbar, "onDrawEnd", function (geometry) {
m_map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 3)));
var identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 0;
identifyParams.returnGeometry = true;
identifyParams.layerIds = queryLayers;
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = m_map.width;
identifyParams.height = m_map.height;
identifyParams.geometry = geometry;
identifyParams.mapExtent = m_map.extent;
var identifyTask = new esri.tasks.IdentifyTask(m_basemapLayer.url);
identifyTask.execute(identifyParams, function (identifyResults) {
dojo.forEach(identifyResults, function (identifyResult) {
if (identifyResult.geometryType == "esriGeometryPolygon") {
var geometryService = esri.config.defaults.geometryService;
geometryService.intersect([identifyResult.feature.geometry], geometry, function (intersectLines) {
intersectLines;
}, function (error) {
error;
then i can get intersected PolyLines. but this is not done.How to get intersected Points?sorry my English. see my attachment image file. please.[ATTACH=CONFIG]19273[/ATTACH]
