Widget Panel size on Mobile
1198
8
10-13-2017 09:47 AM
BrandonPrice
Hello,
I am using a tabbed theme. I would like to reduce the panel size of my bookmark widget which I put in one of the onscreen widget placeholders if possible. I was able to do this on the pc through config.json using height and width, but not yet on a mobile device. Primarily the height if possible would be good. Any suggestions?
Brandon
https://community.esri.com/groups/web-appbuilder-custom-themes?sr=search&searchId=886bfd4e-3db3-4927...
https://community.esri.com/community/gis/web-gis/web-appbuilder?sr=search&searchId=886bfd4e-3db3-492...
RobertScheitlin__GISP
Brandon,
   To do that you need to make some code changes in the jimu/PanelManager.js getPositionOnMobile function (lines 12-14):
    getPositionOnMobile: function(panel){
      //the position is minimized as title, half widget/height, full screen
      if(typeof panel === 'string'){
        panel = this.getPanelById(panel);
        if(!panel){
          return {};
      var box = html.getMarginBox(window.jimuConfig.layoutId);
      var titleTop = box.h / 2;
      if(panel.label === "Bookmark"){
        titleTop = titleTop + 50;
Brandon,
        if(!panel){
          return {};
BrandonPrice
Hey Robert,
Thanks for the suggestion. I couldn't get that to go. My code looks like this:
if(!panel.titleHeight){
   panel.titleHeight = 35;
Image:
The box for the widget expanded to take up the entire screen.
Result
What about not having it openatstart on mobile and only on phone as another solution?
-Brandon
Brandon,
  OK, I am not following... With my code change this is what I am seeing:
Left is the bookmark widget which compared to the right directions widget which is standard height.
BrandonPrice
I relabeled my bookmark widget from "Bookmark" to "Zoom to Hotspot" and that's what the problem was. Thanks Robert. Last thing about using the bookmark widget on a mobile, can the widget appear above the sidebar controller? The default is underneath. Maybe a css z value added to a class or something?
Brandon,
   See if this helps. In the main confid.json find the bookmark widget and add zIndex to the position property (line 8):
        "position": {
          "left": 95,
          "top": 45,
          "width": 380,
          "height": 410,
          "relativeTo": "map",
          "zIndex": 202
        "placeholderIndex": 1,
        "id": "_47",
        "closeable": true,
        "uri": "widgets/Bookmark/Widget",
        "version": "2.5",
        "name": "Bookmark",
        "config": "configs/Bookmark/config_Bookmark.json",
        "openAtStart": true
BrandonPrice
Hi Robert,
This works too. Thanks. This is great. I adjusted the index level from 202 to 102 because it was showing on top of the splash pages.
-Brandon
DavidTreering2
New Contributor III
I found that getPositionOnMobile in jimu.js/PanelManager.js does not work in the Launch Pad Theme, but found it very useful in the Foldable Theme.  Is this a known issue?
BrandonPrice
Hi Dave,
I have only used getPositionOnMobile for the tabbed. Does anyone else know?
Brandon
