Widget modification
2308
03-25-2016 08:05 AM
QaziIqbal
I updated the Basemap Gallery Widget and in Edit.html I added one more input box where user can input the overlay service url. I need this service name to be saved in config_BasemapGallery.json together with other information that is saved there.
Every time we edit any basemap, on saving the widget, it updates the config_BasemapGallery.json located under that app folder (server\apps\9\configs\BasemapGallery)
I am not able to write the overlay url in the config_BasemapGallery.json that the user enters in the new custom field in Edit.html.
I need help to know which function is used when the user hits SAVE. I am not able to find that.
Qazi
RobertScheitlin__GISP
Qazi,
  Are you setting your new overlay url as a new property of the basemap object that is returned from the Edit.js? The function that actually sets the info to the json is the getConfig function in the Setting.js
QaziIqbal
Robert
I was working on modifying the basemapgallery widget to give an option to users to add dynamic service on top of base map which will be parcels layer in our case. I completed it.
Thanks for the reply and it helped. I will mark this as correct answer.
