WAB 3D custom widget Add Shapefile works, but no pop-up
511
09-07-2020 05:47 AM
MichaelLev
I created WAB 2.17 3D custom widget to add zipped shapefile. Its code is exactly as in sandbox of esri Javascript API 4.16 code example Create a FeatureLayer from a shapefile. It runs OK and I see the added shapefile both in the 3D scene and in "Layer List" widget.
My questions:
  1. If I run esri example or if I copy esri code example into an independent web app, then when I click on an added feature, a pop-up is opened, as expacted.
    But - In my WAB, I have a serious problem - When I click on an added feature, no pop-up is opened.
    I attach the relevant part from my Widget.js which is exactly as in esri example.
  2. I tried to manually define a feature layer popupTemplate, then I see it, but
    1. I have not succeeded to immitate the esri default templatePopup - see my other question
    2. I don't understand why the default popup does not appear and the manual popup do appear.
  3. I don't understand the comment in line 171 in the example, since anyway with esri example, the popup is opened by click. Does the comment mean that this is the place if I want to write code that changes the pop-up template?
The above is a great "show stopper" problem for me.
Help will be greatly appreciated,
Michael
MichaelLev
MichaelLev
Dear Robert Scheitlin, GISP‌,
no one has yet replied to this wuestion,
can you help, please?
Michael
MichaelLev
Answered in my other question.
Michael
