Use geoenrichment service in Web App Builder
842
11-15-2016 12:57 PM
ZhujingXia
Occasional Contributor II
I'd like to see any widget could use geoenrichment service to create demographis report in Web App Builder application.
DerekLaw
Esri Esteemed Contributor
Hi Zhujing,
FYI, the Analysis Widget has the Enrich layer tool which enables you to work with the geoenrichment services from ArcGIS Online. It does not create a report, but it does enable Web AppBuilder to leverage data from geoenrichment services.
Hope this helps,
ZhujingXia
Derek,
Yes. I found the analyst widget in Web app builder, it is would be nice if some one could customize it so it could create a report, or customize the analysis widget to make it more simple, so the user no need to choose what variables (it could choose the variable when config the widget).
Thanks
