Strange Identify Widget problem: identified all parcels on the same horizontal level (when zoomed in)
979
11-19-2020 03:13 PM
BingJing
New Contributor III
This happens only when I  really zoomed in (only have 4-6 parcels on screen). When I use Identify tool to click on one parcel, all the parcels on the same horizontal level is selected.  Identify widget works fine If I do not zoom in this close.  I am using Robert's identify widget.
Anyone has any clue why this is happening? Thank you
Please see attached screen copies.
RobertScheitlin__GISP
Out of hundreds of users no one has reported this type of issue. What Identify tool are you using (i.e. point, extent, etc)?
BingJing
New Contributor III
My fault. I modified so many lines that I do not know which one caused this.  So I just re-downloaded the original Identify and all is fine. Now I have to add back all my modifications.
Thank you, Robert, for the reply. I would not be able to finish this project without your help.
BingJing
New Contributor III
I was using Point tool. I disabled all others ID tool except Point.
