SOS!!! change my arcgis server URL from localhost:6080 to an arcgis URL
878
6
05-17-2020 08:57 AM
MedMZOURI
hey guys I have a problem I want to change my arcgis server URL from localhost:6080 to an arcgis URL..because when I publish my geoprocessing services and I want to add a custom widget in web appuilder I can't add it . I can add some public geoprocessing services of other people who have a URL different from localhost:6080..that"s why I want to change my server url from localhost:6080 to an arcgis url..
PS: I don't have Portal for arcgis..or rather I have installed it but I don't have license for it
JoshuaBixby
Can you elaborate on what you mean by "arcgis URL"?
Have you tried connecting to http://hostname.domain.com:6080/arcgis to publish instead of http://localhost:6080/arcgis to publish?
MedMZOURI
Not Yet..by arcgis URL I mean a URL which does not contain "localhost"
JoshuaBixby
The first thing I would try then is using hostname.domain.com to connect and publish.
MedMZOURI
is it obligatory to have installed portal for arcgis?
MedMZOURI
I don't have a domain name so what is domain.com?
JoshuaBixby
Any computer on a business network will have a fully-qualified domain name (FQDN).  Usually the domain name is the same or similar as the company domain, e.g., server01.esri.com or something like that.
Open PowerShell and put the following in:
[System.Net.Dns]::GetHostByName(($env:computerName))
