All,
Here is a list on my currently available Web AppBuilder widgets for Web AppBuilder 2.x
Enhanced Search Widget Version 2.21 - 11/16/21 Download Link
Enhanced Basemap Gallery Widget 2.8 - 05/01/2018 Download Link
Share Widget Superseded by esri OTB share widget
Share Widget Version 2.0.1 - 04/20/16 Download Link
Identify Widget Version 2.21 - 11/16/2021 Download Link
Elevation Profile Widget Version 2.17 - 09/19/2020 Download Link
Map Progress Indicator Widget Version 2.14 - 11/26/2019 Download Link
Enhanced Bookmark Widget Version 2.5 - 08/17/17 Download Link
Enhanced Locate Widget Version 2.16 - 08/21/2020 Download Link
Popup Panel Widget Version 2.17 - 9/1/20 Download Link
Aloha Threat Zone Widget Version 2.9 - 09/27/18 Download Link
Url Button Widget Version 2.5 - 08/10/2017 Download Link
Layer Toggle Button Widget Version 2.14 - 01/13/2020 Download Link
Feature Layer Hover Widget Version 2.12 - 09/05/2019 Download Link
Message was edited by: Robert Scheitlin, GISP 11/16/2021
Saif,
There are a number of threads that deal with that subject.
Thanks Robert for these great widgets. Just wonder can you think a reason that the WAB2.5 widgets wouldn't work in WAB 2.7? I understand the 2.5 widgets were developed and tested using WAB 2.5, but both 2.5 and 2.7 use the similar versions of API and the API supposes backward compatible. Please advise.
Each release of WAB uses a new version of the JS API. so that could be the issue. What are the errors presented in the browsers web console?
Robert, I have WAB 2.7 installed and am planning to install your 2.5 widgets. I am just checking with you to see if these 2.5 widgets are going to work in WAB 2.7 or not. the API versions used by 2.5 and 2.7 have minor differences. Hope the 2.5 widgets are going to work in 2.7.
Alex,
If there are any breaking changes in WAB to my widget or I make enhancements to them then new versions are released. If the widget is till at version 2.5 then it will work in 2.7 or else I would have released a new version that is compatible with the latest release. So if there is no breaking changes in the latest WAB release and I have not enhancements or bug fixes for a widget it will remain at the last version.
Hey Robert, any thoughts on creating a widget that allows the end user to submit feedback on the website to the organization? Maybe something simple like a button that could be configured to send an email to an email address specified by the website developer?
Amy, I am chiming in only because I am dealing with the same point you are making. In my case, instead of going through the hassle of building a whole widget just to send an email, I solved it by adding a "Contact Us" link to header of the web app and then went into the main config.json file and added "mailto:<your_email_here>" into the existing "url" property of the "Contact Us" field. Wouldn't this work for you as well?
Simple, yet elegant. My favorite kind of solution! Thanks, Francesco.
Robert Scheitlin, GISP, I continue to be a huge fan! I've got a question - I'm working with a customer that is still stuck on 10.4.1, and using Web AppBuilder 1.x (I think it's 1.10). I tried looking for older versions of your widgets, but couldn't figure out how to get them. Any pointers?
Thanks, keep up the great work!
Joe
Joe,
I have my old 1.1 widget which specifically?
