All,
Here is a list on my currently available Web AppBuilder widgets for Web AppBuilder 2.x
Enhanced Search Widget Version 2.21 - 11/16/21 Download Link
Enhanced Basemap Gallery Widget 2.8 - 05/01/2018 Download Link
Share Widget Superseded by esri OTB share widget
Share Widget Version 2.0.1 - 04/20/16 Download Link
Identify Widget Version 2.21 - 11/16/2021 Download Link
Elevation Profile Widget Version 2.17 - 09/19/2020 Download Link
Map Progress Indicator Widget Version 2.14 - 11/26/2019 Download Link
Enhanced Bookmark Widget Version 2.5 - 08/17/17 Download Link
Enhanced Locate Widget Version 2.16 - 08/21/2020 Download Link
Popup Panel Widget Version 2.17 - 9/1/20 Download Link
Aloha Threat Zone Widget Version 2.9 - 09/27/18 Download Link
Url Button Widget Version 2.5 - 08/10/2017 Download Link
Layer Toggle Button Widget Version 2.14 - 01/13/2020 Download Link
Feature Layer Hover Widget Version 2.12 - 09/05/2019 Download Link
Message was edited by: Robert Scheitlin, GISP 11/16/2021
Hi Robert, thanks for putting together these widgets.
It would be great to build a better time slider widget -- where you can update the time extent in the widget. Currently that's missing and makes the time slider not very useful.
Morning Landon,
Did you get a solution to this issue ? I'm interested to know if the time slider can be honoured by the summarize widget. Have you encountered this issue before ?
Regards.
Jeremy.
Jeremy,
Unfortunately those widgets do not respect the time sliders time extent and would take a good deal of work to make them do that. You will need to request enhancements for those widgets to be time aware.
Hi Jeremy,
I have not found a resolution yet — but I haven’t been working on it. Please let me know if you figure it out!
Hi Robert,
Sorry to hassle you. Will the current versions of your widgets work with WABD 2.2?
Rod
Rod,
Eventually I will be doing 2.2 version but yes the 2.1 versions will work fine in WAB 2.2
Hello! Is there a widget for version 2.1 of the web appbuilder that runs buffer? I need to request some parameters for the user, among them the distance, and after, I have to circulate the area referring to the radius of the point found on the map. I tried using the geoprocessing widget, but I was not successful. Thanks for any help.
Gilberto,
The eSearch widget allows you to buffer a point clicked on the map or a feature selected by a query.
Many thanks Robert. I'll check. hug
Robert,
This is great. I guess I'll have to try out eSearch!
Cheers,
Barnaby
