Programatically modify widget name when the widget is opened
621
11-04-2020 04:12 AM
MichaelLev
Occasional Contributor III
I'm developing custom widgets for WAB (Develper Edtion) 2.17, Launchpad Theme, on 3D Scenes (ArcGIS API for javascript 4.17).
I need to change the title of my custom widget window, AFTER the widget has been opened, so that the title will be changed both in the widget-window-title and also in the widgets-group-panel.
I want the change to take effect only when the app is running, and vanish when the app is closed.
I'll appreciate info how to do it.
RobertScheitlin__GISP
Michael,
Can you provide a screenshot to better explain?
MichaelLev
Dear Robert,
Thank you for attending to my question.
I'm attaching a screenshot of part of my query widget.
As you can see, I let the user select on which layer he wants to make the query.
So, I want to rename the widget, both in its title and in the name shown when I hover on the icon in the "Launchpad Theme" widgets-panel. I want that I will be able to add the layet title to the widget name.
It's even more important in case I put some similar widgets in widget-group, and I want that the widget name will include the name of the selected layer, so instead of "Filter Layer" it will be e.g. "Filter TLV_2_Neighbourhoods".
Thanks
Michael,
  Here is some code that shows that. This full widget code is the otb Legend widget modified.
define([
    'dojo/_base/declare',
    'jimu/BaseWidget',
    'esri/widgets/Legend',
    'jimu/WidgetManager',
    'dojo/_base/html'
  ], function(declare, BaseWidget, Legend, WidgetManager, html) {
    var clazz = declare([BaseWidget], {
      baseClass: 'jimu-widget-legend',
      templateString: "<div><div data-dojo-attach-point='legendDiv'></div></div>",
      abc: null,
      postCreate: function(){
        this.inherited(arguments);
        this.legend = new Legend({
          container:this.legendDiv,
          view:this.sceneView
      destroy: function(){
        if(!!this.legend){
          this.legend.destroy();
      onOpen: function(){
        var parentWid = html.getAttr(this.domNode, 'widgetId');
        var iconNode = this.getAnchorbarControllerNode(parentWid);
        this.parentContainer = iconNode;
        html.setAttr(this.parentContainer.tooltipDialog, 'content', "Legend Widget New Title");
        var panel = this.getPanel();
        html.setAttr(panel.titleLabelNode, 'innerHTML', "Legend Widget New Title");
      getAnchorbarControllerNode: function(id) {
        this.abc = WidgetManager.getInstance().getWidgetsByName("AnchorBarController")[0];
        return this.abc._getIconItemById(id);
      onClose: function(){
        html.setAttr(this.parentContainer.tooltipDialog, 'content', "Legend");
        html.setAttr(this.getPanel().titleLabelNode, 'innerHTML', "Legend");
    return clazz;
MichaelLev
Dear Robert,
Thank you very much!
I'll check it tomorrow.
